Discover an up-to-date overview of third-party devices that have been tested for interoperability with ctrlX OS and ctrlX AUTOMATION.
General information
The communication is done via EtherCAT, OPC UA, Standard Ethernet, or other ways as listed and their respective apps for ctrlX OS.
This list is continuously growing and helps you find compatible products for your applications faster.
The list is not complete and will be extended or corrected as new devices are tested.
It is just a snapshot, with different versions of the device firmware/hardware or controller firmware the behavior can be different.
👉 Do you know a device that is missing here?
You’re welcome to share it with the community – please fill out directly our form here.
ctrlX World Partner can enter their devices directly via the ctrlX OS Ecosystem Portal.
Vendor overview
ArduinoBalluffBeckhoffBeldenBosch BT - AviotecBosch RexrothDelta ElectronicsFaulhaberFestoHilscherifmKassow RobotsKEBAKochLappLinMotmaxonPepperl-FuchsSchmersalSchunkSICKSMCSynapticonTurckWAGO
Interoperability status
LIMITED - only limited usage possible
OK - no known problems
NO - not functioning with not functioning with ctrlX OS EtherCAT Master
[table]
Vendor
Product
Description
Communication App
Status
Arduino
Arduino
low-power development board equipped with advanced sensors for motion and environmental monitoring
ctrlX Standard USB
OK
Balluff
Balluff
EtherCAT Multi-frequency RFID processors
ctrlX EtherCAT Master
OK
Balluff
OK
Balluff
OK
Balluff
OK
Balluff
EtherCAT IP67 IO Link bus coupler
OK
Balluff
OK
Balluff
OK
Balluff
OK
Balluff
OK
Balluff
OK
Balluff
OK
Balluff
Magnetostrictive linear position sensors
OK
Beckhoff
Beckhoff
EtherCAT compact bus coupler
OK
ok, but instead of BKxxx/KLxxxx it is recommended to use EKxxxx/ELxxxx
Beckhoff
Infrastructure, 8-port junction, EtherCAT
LIMITED
instead use EK1100 and several EK1122
Beckhoff
EtherCAT Coupler
OK
Beckhoff
EtherCAT Coupler with ID switch
OK
Beckhoff
EtherCAT Coupler with EtherCAT Terminals (ELxxxx) with ID switch, Fast Hot Connect
OK
Hot Connect Groups not supported by EtherCAT Master
Beckhoff
EtherCAT extension, E-BUS conversion to 100BASE-TX Ethernet
OK
Beckhoff
2-port EtherCAT junction (star topology)
OK
Beckhoff
EtherCAT P coupler
OK
Beckhoff
2-port EtherCAT P junction with feed-in
OK
Beckhoff
EtherCAT bus coupler with ID switch, plastic optical fibre
OK
Beckhoff
1-port EtherCAT plastic optical fibre junction
OK
Beckhoff
2-channel digital input terminal 24 V DC, 3 ms
OK
Beckhoff
4-channel digital input terminal 24 V DC, 3 ms
OK
Beckhoff
8-channel digital input terminal 24 V DC, 3 ms
OK
Beckhoff
2-channel digital input terminal 24 V DC, 10 µs
OK
Beckhoff
4-channel digital input terminal 24 V DC, 10 µs
OK
Beckhoff
2-channel digital input terminal 24 V DC, 1 µs, timestamp
OK
Beckhoff
8-channel digital input terminal 24 V DC, 1 µs, multi-timestamp
OK
Beckhoff
2-channel digital input terminal 24 V DC, 1 µs, oversampling
OK
Beckhoff
2-channel digital output terminal 24 V DC, 0.5 A
OK
Beckhoff
4-channel digital output terminal 24 V DC, 0.5 A
OK
Beckhoff
8-channel digital output terminal 24 V DC, 0.5 A
OK
Beckhoff
4-channel digital output terminal 24 V DC, 0.5 A, with diagnostics
OK
Beckhoff
2-channel digital output terminal 24 V DC, 0.5 A, push-pull, tristate
OK
Beckhoff
2-channel digital output terminal 24 V DC, 0.5 A, 1 µs, timestamp
OK
Beckhoff
8-channel digital output terminal with multi-timestamping
OK
Beckhoff
1-channel analog input terminal, current 4…20 mA, 12 bit, differential
OK
Beckhoff
2-channel analog input terminal 0…10 V, single-ended, 12 bit
OK
Beckhoff
2-channel analog output terminal 0…10 V, 12 bit
OK
Beckhoff
IO-Link terminal
NO
Beckhoff
Ethernet switch port terminal (EoE)
OK
Beckhoff
PROFINET RT controller/device terminal
NO
Beckhoff
EtherCAT Terminal, 2-port communication interface, PROFINET RT, device
LIMITED
Configuration via Startup Parameter and/or TwinCAT SCI import
Beckhoff
PROFINET IRT controller
NO
Beckhoff
EtherNet/IP master terminal
NO
Beckhoff
EtherCAT Bridge
LIMITED
With Ethercat Master App V1.10.1 the AL status doesn't get reset upon switching from Init to OP. Bugfix should be available with Patch RM21.11A. It is recommended to use EL6695 instead.
Beckhoff
PROFIBUS master/slave terminal
LIMITED
Configuration via Startup Parameter and/or TwinCAT SCI import, Hardware revision >= EL6731-0000-0025
Beckhoff
EtherCAT Terminal, 1-channel communication interface, PROFIBUS, slave
LIMITED
Beckhoff
CANopen master/slave terminal
NO
Beckhoff
DeviceNet master/slave terminal
NO
Beckhoff
TwinSAFE Logic
NO
not possible to load Beckhoff TwinSAFE project
Beckhoff
TwinSAFE/PROFIsafe logic and gateway terminal
NO
Beckhoff
1-channel motion interface, stepper motor
OK
Beckhoff
Power supply terminal for E-bus, with diagnostics
OK
Beckhoff
IO-Link terminal
NO
Beckhoff
stepper motor module
OK
tested without encoder
Beckhoff
EP1918-0002
8-Channel-Digital-Input Safety
OK
Belden
Belden
Managed Switch
ctrlX OPC UA PubSub
OK
Bosch BT - Aviotec
Bosch BT - Aviotec
cameras for advanced video-based fire detection systems
Eclipse Mosquitto MQTT Broker
OK
Bosch Rexroth
Bosch Rexroth
Drive
OK
Bosch Rexroth
IO system
OK
Bosch Rexroth
IndraDrive with CAN application profile (CoE)
OK
Bosch Rexroth
IndraDrive with Servo drive profile (SoE)
OK
Bosch Rexroth
KE350
Tightening System
OK
With IMecat see:
https://community.boschrexroth.com/communication-5ojipb0n/post/ethercat-tightening-imecat-module-PREmLqyXKVt3wE9
Bosch Rexroth
Power Supply
IndraDrive Power Supply
OK
Bosch Rexroth
EtherCAT S20 bus coupler
OK
please have a look at this post(https://community.boschrexroth.com/ctrlx-i-o-1lgjjr0v/post/which-s20-io-modules-are-supported-on-the-s20-ethercat-bus-coupler-z0ZF7fBn0TmZ6uM), to see which modules are supported
Bosch Rexroth
S20-IOL-8 at S20-EC-BK
EtherCAT ctrlX CORE X3 and XM
OK
we have function blocks to configure in CXA_S20 and RIH_IndraControl_S20
Bosch Rexroth
Safety control
OK
Delta Electronics
Delta Electronics
OK
Integration to EtherCAT works well. With motion app >=V2.2, the axis can be controlled from motion app
Faulhaber
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Servo Drive
OK
Faulhaber
CiA 402 Motion Control System
OK
Faulhaber
OK
Festo
Festo
Modular remote I/O-System
OK
Festo
Decentral I/O-System IP65/67
OK
Festo
IP20 Cabinet IOs
OK
Hilscher
Hilscher
PC card PCI - EtherCAT-Slave
OK
Hilscher
EtherCAT/Profibus Gateway
OK
Hilscher
NXHS 500
Evaluation Board Real-Time-Ethernet
OK
Hilscher
NXIO 50
OK
Hilscher
NXIO100
OK
ifm
ifm
EtherCAT IO-Link Master 4 Port IP67
OK
ifm
EtherCAT IO-Link Master 4 Port IP69K
OK
ifm
EtherCAT IO-Link Master 8 Port IP67
OK
ifm
EtherCAT IO-Link Master 8 Port IP69K
OK
ifm
OK
ifm
OK
ifm
OK
ifm
OK
ifm
EtherCAT IO-Link Master 8 Port IP20
OK
ifm
EtherCAT Digital Input Modul 8 Port IP67
OK
ifm
EtherCAT Digital Input Modul 8 Port IP69k
OK
ifm
OK
ifm
OK
Kassow Robots
Kassow Robots
Robot Controller for Kassow Robots cobots
CODESYS PROFINET
OK
KEBA
KEBA
mobile HMI panel
ctrlX PLC
OK
KEBA
mobile HMI panel
ctrlX OPC UA Server
OK
Koch
Koch
Active energy management with external storage (Super caps)
OK
Lapp
Lapp
Condition monitoring device for Ethernet
ctrlX Standard Ethernet
OK
LinMot
LinMot
CiA 402 Servo Drive
OK
Successfully tested with motion app >=V3.6.2. The axis can be controlled from motion app.
LinMot
Cia 402 Servo Drive (FSoE)
OK
maxon
maxon
Drive
OK
maxon
EtherCAT slave for stepper motor, BLDC, etc.
OK
Pepperl-Fuchs
Pepperl-Fuchs
Absolute encoder with EtherCAT interface
OK
Pepperl-Fuchs
IO-Link Master
OK
Pepperl-Fuchs
RFID-Reader
OK
Schmersal
Schmersal
Safety fieldbox for EtherCAT with FSoE
OK
Schunk
Schunk
electric gripper
ctrlX PLC
OK
SICK
SICK
vision sensor
OK
SMC
SMC
Stepper motor controller
OK
SMC
Valve manifold controller
OK
Synapticon
Synapticon
Drive
OK
Turck
Turck
EtherCat IO-link Master
OK
Turck
RFID Module for EtherCAT
OK
WAGO
WAGO
I/O System
OK
WAGO
decentralized IP67 I/O-System
OK
