11/06/2024
Bosch Rexroth | Solution Sets | IoT
Remote Access & Remote Management Portfolio
Usecase:
Did you know that ctrlX OS enables remote access and remote management for your machines? Actually it is  available on ctrlX CORE devices such as the CORE X3, CORE X5, and CORE X7. This functionality can be achieved using legacy tools or applications available in the ctrlX WORLD. However, what distinguishes remote access from remote management? continue to read! The image below illustrates the system layout applicable to both scenarios.
Remote Access:
the ability to access and control a computer or other electronic device from a remote location. This capability enables quick troubleshooting, adjustments, and updates, ultimately reducing downtime and increasing productivity.
Remote Management: the possibility controlling and maintaining devices from a distance, including tasks like troubleshooting, updates, and asset tracking, often without user interaction. The ctrlX Device Portal is our legacy solution for Remote Management and Remote Access (coming soon).
ctrlX Solutions Remote access
With ctrlX OS you can:
  • Remotely manage your ctrlX OS devices through the ctrlX Device Portal and perform mass deployments of your software.
  • Use other applications from the ctrlX World to perform full functional remote access to your device and anything in its network.
  • Enjoy seamless monitoring, control, and troubleshooting of your devices and network from anywhere, at any time.
Commercial Solutions Available & How to Choose Between Them
With a vast array of solutions available, each with its own strengths and deployment scenarios, it is essential to take a strategic and informed approach to choosing the optimal solution. Below is a comparison table to help you select the service that best suits your needs. When making your decision, consider the following key factors:
  1. Do you require remote access to the machine LAN?
  2. Do you need an integrated fleet manager for ctrlX OS?
  3. Which business model is most suitable for you: subscription or single purchase?
ctrlX Solutions Remote Access - Overview
How To start?
You can try running any of these solutions using the resources listed below. Scroll down for the BOM!
Solution
Producer
Docs
Other
First Steps
ctrlX Device Portal
Rexroth
Ask for the premium account and follow the documentation.
IXON Cloud
IXON
IXON Cloud ConnectorHow-To: BasicHow-To: Advanced
Sales Presentation
Video Tutorial
Install the app, Login to the portal. Follow the Guides and the video tutorial.
MBConnect Line
MBConnect
How-To
Install the VPN app, Get the MBconnect OpenVPN service and try it out.
Break free from boundaries: use your own infrastructure to remote access ctrlX OS
Are you tired of standard commercial solutions that don't quite fit your needs? Do you trust just your infrastructure? Do you require a customized approach to secure your online connections?  use the VPN Client app  to connect to your server based on OpenVPN or IPSec technologies.
With our app, you're in control, allowing you to design and implement a VPN solution that perfectly suits your specific requirements.
BOM and standard configurations
ctrlX Configurator link: Click Here!
Standard BOM:
IXON
Product
Material Number
Typecode
Needed?
IXON - Cloud Connector
R911422340
SWL-W-XC*-IXAG*IXON*REMOT-NNNN
Mandatory
ctrlX OS - Firewall
R911430062
SWL-XC*-FRW-FIREWALL*****-BANN
Mandatory
ctrlX OS Device
MBConnect line and Do It Yourself solution
ctrlX Configurator Link: Click Here!
Standard BOM:
Product
Material Number
Typecode
Needed?
ctrlX OS - VPN Client
R911400506
SWL-XC*-VPN-VPNCLIENT****-NNNN
Mandatory
ctrlX OS - Firewall
R911430062
Mandatory
ctrlX OS Device
Solution Sets
