03/06/2023
Bosch Rexroth | Web Application | Engineering
EPLAN Article Data Generator
The EPLAN article data generator is a web application that enables the generation of device data based on the unique type code of a Bosch Rexroth product. Subsequently the data sets are provided as standard EDZ files.
The integration of the web application into the online product catalog allows a comfortable access to the EPLAN data sets.
Calling the generator via the EPLAN Data Portal makes it possible to place the generated macros directly on a worksheet of EPLAN Electric P8. In addition, the EPLAN generator is seamlessly integrated into the ctrlX Configurator to provide a quick provision of the data sets for a configuration result.
Generation and provision of the EPLAN data
EPLAN Article Data Generator Main Screen
For easy access to the EPLAN data, the generator is also integrated into the ctrlX Configurator
EPLAN Data Generator Integrated In ctrlX Configurator
Download comfortably all EPLAN datasets of a configuration via a collective order …
EPLAN Data Generator Collective Order Status
... and then use the datasets in EPLAN Electric P8
Ā
Use Data Sets In EPLAN Electric P8
Ā
[link-button type="primary" text="START EPLAN GENERATOR" target="_blank" href="https://ecad-configuration.boschrexroth.com/overview?downloads=true&uc=overview/"]
Forum ctrlX Services
Categories
Engineering
Platform
Web Applications
Vendor
Bosch Rexroth AG
