11/20/2024
How-to | Jochen_Mueller | Nov 13, 2024
Template for Consumer Goods - Form, Fill and Seal
The Form Fill & Seal Machine (FSS) Application Template for ctrlX AUTOMATION starts with a basic template for vertical FSS (VFFS).
It includes a PLC, based on PackML state machine, and a HMI project as well as configuration data, 3D-viewer model and WebIQ project. It is created for the usage in form, fill and seal machines.
It will be provided in two different formats:
  • Ready-made virtual control (easy to use also for non-technical people 😊)
  • Several project files
    • PLC archive (including all necessary libraries)
    • HMI
    • Core app-data
[youtube src="https://www.youtube.com/embed/QnVnczpFyUk?si=1MzprIBbpaJpotQF"]
Available Versions
  • Versions 0.0.0.8 - PreRelease
    • It is based on the ctrlX CORE release version 2.6.2 (RM24.03.2).
    • Features and Prerequisits see below
Features
  • Support of a basic VFFS Machine (1x Master Axis, 2x Belt Axis, 1x Vertical Axis, 1x Jaw-Axis)
  • PLC Project
    • based on PackML machine states and PackTags
    • MotionInterface used for axis command/status.
  • Web-IQ Application with basic screens for
    • Machine Mode Handling.
    • Prepared Job Handling (Format Change, ...) - only prepared HMI screens yet!
      More is coming soon.
    • Diagnostics (error log, ....)
    • 3D Viewer visualizing the complete FSS machine movements.
  • Machine Modes
    • Production – to start/stop machine, run with changeable machine command speed.
    • Manual – to jog machine (jog all axis synchronized).
    • Maintenance – jog single axis.
For using ready-made virtual control
For using ctrlX CORE Hardware
  • ctrlX CORE
    • Ethercat App (2.6.3) with license
      • ctrlX OS License - EtherCAT Master Basic
        R911400508 - SWL-XC*-ECM-ETHERCATMAS**-BANN
    • Motion App (2.6.4) with license
      • ctrlX OS License - Motion Standard 10 Axes
        R911414460 - SWL-XC*-MOT-STDMOTION**10-NNNN
      • ctrlX OS License - Motion Electronical Gear(add-on)
        R911417992 - SWL-XC*-MOT-ELECGEAR*****-NNNN
      • ctrlX OS License - Motion CAM (add-on)
        R911417993 - SWL-XC*-MOT-CAM*********-NNNN
      • ctrlX OS License - Motion Flexprofile (add-on)
        R911417994 - SWL-XC*-MOT-FLEXPROFILE**-NNNN
    • PLC App (2.6.3) with license
      • ctrlX CORE License - PLC Basic (02VRS - single core, single task and 256 byte IO data)
        R911421866 - SWL-XC*-PLC-PLC*XOS******-BANN
      • ctrlX CORE License - PLC Standard (02VRS - single core, multiple tasks and 1 kByte IO data)
        R911421867 - SWL-XC*-PLC-PLC*XOS******-NNNN
    • OPC UA Server App (2.6.2) with license
      • ctrlX OS License - OPC UA Server Standard
        R911397816 - SWL-XC*-UAS-OPCUASERVER**-NNNN
    • 3D Viewer App (2.6.0) with license
      • ctrlX OS License - 3D Viewer
        R911413191 - SWL-XC*-3DV-3DVIEWER*****-NNNN
    • WebIQ Server Runtime App (2.15.7) with license
      • ctrlX CORE License - Smart HMI - WebIQ Server 500 Tags (~ 490 Tags used, will be optimized)
        R911410793 - SWL-W-XC*-WIQ**RUD*500***-NNNN
Unpacking
For installation / usage information please take a look into the VFFS template.
[link-button type="light" text="VFFS Application Template" target="_blank" href="https://www.boschrexroth.com/de/de/myrexroth/collaboration/collaboration-rooms/?path=%2FCtrlx-Automation%2FctrlX_CORE_APPS_Releases%2FctrlX+SolutionSet%2FPackaging%2FVFFS&page=1&search="]
Notes
  • These templates are made for the system version 2.6.2 (RM24.03.2) and the corresponding apps.
  • Beware of moving mechanics when using automated motion commanding.
  • The 3D Viewer is in standard always showing the demo model, please check the documentation for how to set the corresponding path to another one.
Related links
3
VFFS Template - First Steps02.pdf
1.03MB
Solution Sets
HMI
Motion
Packaging
