12/15/2023
Set up a ctrlX CORE and PLC Programming
Overview
Here you can find two examples, one for a ctrlX COREvirtual and one for a ctrlX CORE, setup some axes and a robot via the web interface, EtherCAT configuration with ctrlX IO Engineering and PLC programming with ctrlX PLC Engineering. If you like to see how they were set up watch the corresponding how-to video "How to #2 Set up a ctrlX CORE & PLC Programming":
Preparation
How to load the examples
To see how the attached examples can be loaded and changed between a ctrlX COREvirtual and a ctrlX CORE please check the video from 37:20 on, How to #2 Set up a ctrlX CORE & PLC Programming.
The configurations are "developRvirtual.zip" and developRreal.zip"
The ctrlX IO Engineering and the ctrlX PLC Engineering Projects can separately found in "Projects.zip" or loaded online after uploading the configurations.
Notes
  • These examples are made for the release version RM21.03 (V1.8.x) of the corresponding apps.
  • Beware of moving mechanics when using automated motion commanding.
Related links
developRvirtual.zip
1020.85KB
developRreal.zip
1.96MB
Projects.zip
506.3KB
