Connect application in WSL to DL in virtual CORE
when I am trying to follow the descriptions within the python and goLang example projects on how to connect to the DL of a virtual CORE, it is not working for me.
First of all, I disabled the check on "SNAP" environment, as in WSL is was always true and returned "ipc://". The string address is not working with any IP I enter. Did anybody of you faced the same issue? It would speed up my development if I could run the code manually first instead of building and deploying the app every time.
Thanks and best,
Karim
Best reply by nickH
Hi K-Zanaty,
V1.20 is the latest LTS (long term support) release, these versions are published once a year end of July. In between LTS versions we got early adopter releases, that are published every 4 months. See more information about our release cycle in: Release cycle of ctrlX OS, apps and engineering software.
If you want to get access to the early adopter releases, see here how to do that: FAQ for ctrlX Store.
You can still use V1.20 SDK and App Build Environment if you like, but there is one issue, when you want to use the App Build Environment and SDK V1.20. See my post in the forum.
