A customer was evaluating ctrlX so he installed ctrlX WORKS. Now wants to remove ctrlX WORKS from his PC. After uninstall, the ctrlX PLC Gateway remains. This can be seen with the flashing icon in the taskbar. I see this also when I install and remove ctrlX WORKS from a virtual machine. I uninstalled by running the installation .exe again, selecting Modify and then Remove. I tried this with ctrlX WORKS 1.12. I also repeated the procedure, only this time making sure the service was Stopped before uninstall, but this made no difference.
Is this a bug with the ctrlX WORKS/Codesys install package, and is there a good method to remove this?
Brian
