Ethercat stuck in safe- OP (sync manager watchdog)
we have a communication problem about Ethercat.
When Ctrlx is booting, not all Ethercat slaves change in OP automatically:
Our machine configuration include a S20_EC_BK with 2 encoder modules (S20_INC_2).
We try to replicate the issue using a S20_EC_BK with 2 digital  I/O modules, but the error does not occoure.
In particular this happend only with S20_EC_BK with 2 encoder modules (S20_INC_2).
We noticed the difference between the 2  kind of modules is S20_INC_2 can be included only onboard or on a sercos or an ethercat bus coupler.
Have you got any experience about this situation or do you know why could this happened?
Thanks,
Carlotta.
Best reply by cc2go
Hello CarlottaP , in v2.4 and v2.6 was an issue, which is solved with EtherCAT Master ECM-V-0206.2.app, that after reboot all EhterCAT devices will switch to OP.
Can you please check that the S20-EC-BK has at least v1.24 as firmware or higher.
