I have noticed in my testing that if you power-up a dual axis ctrlx Drive with a panel plugged in, that both axes appear on the display as intended. Â
However, if you plug the panel into a dual axis ctrlX Drive after it has already powered up, then only the first axis shows up on the display. Â
I'm interested to know if anyone can repeat this bug. The main scenario where I could see this being problematic is if you have one panel and multiple dual axis drives and you are trying to set the axis address for all drives through the panel.
