I have an application that is polling data from multiple drives and reading mutiple parameters from each drive at a rate of anywhere from ~100ms - ~1sec and see the CPU take a significant hit.  What is the best way to poll parameters from drives using the SIP protocol with drive connect so as to cause the lowest load on the system CPU use? Does subscribing produce a lower load? Does a batch read have lower overhead? What is the best practice?Â
Drive Connect optimal usage
Best reply by Alex
I switched to a newer version of the app (1.20.2) and the problem was fixed.Â
