Barcode Scanner with USB or RS232 with Core X3
We're planning to use a CtrlX Core X3 PLC for our project. We want to use a handheld barcode scanner from Sick with RS232 or USB interface. Currently ethercat is not an option.
Only solution I've found is to use Node-RED. So, I wanted to ask if there is an easier or a standart solution for this issue? Or maybe a spesific brand of barcode reader for a straight forward implementation?
You can find the links for barcode scanners below. Thank you for your help.
https://www.sick.com/tr/en/catalog/products/machine-vision-and-identification/mobile-handheld-scanners/idm/idm141-300s-usb-kit/p/p368644?tab=detail
https://www.sick.com/tr/en/catalog/products/machine-vision-and-identification/mobile-handheld-scanners/idm/idm141-300s-rs-232-kit/p/p368607?tab=detail
Will be discussed in this topic. Please do not post same question in several forums.
