05/11/2022
How-to | HMI | January 25, 2022
WebIQ - Create your first HMI project
Requirements
Install the PLC, OPC-UA Server and WebIQ Runtime apps on ctrlX CORE (minimum requirement).
Step-by-Step guide
Step 1
We will use OPC UA communication to exchange variables between WebIQ and PLC app on ctrlX CORE. First of all, create a Symbol Configuration on the PLC app with all the variables you want to exchange with the HMI. Login and Run the application.
Add a Symbol Configuration on the PLC app
Step 2
Open WebIQ Designer and create a new project. To configure the OPC-UA communication, open the IO Manager. Select “Create Entry” to create an IO Handler and add the hightlighted fields.
Configure OPC UA communication on WebIQ
Note: on crlX CORE verify that the certificates are trusted (otherwise an error concerning the IO Handler creation is displayed).
SMART HMI certificates on ctrlX CORE
Step 3
To create the variables in exchange with the PLC, go to Process Data Manager. Click on the Variables section and use the Browse option.
Browse OPC UA variables
Create a new HMI variable
For more information on how to use the Browse functionality, read the How-To guide WebIQ - Browsing of Variables, Arrays & Structures in OPC UA
Step 4
To display the variable on screen, go to Layout Manager. Select the Widget you want to display the variable in and link the Item to the Widget.
Add a widget to your project
Step 5
Save the project. Click on Publish to transfer the project on the runtime.
Save your project
Step 6
Go to Home. From the Project List, Start the project you want to display on the runtime.
Run the project
Step 7
Go to yourIPaddress:10123/projectname/ using your favourite browser. Insert username and password configured for the project.
Open the browser
Display your project on the browser
You now have your working HMI.
Empowering HMI Excellence
3
HMI
