10/29/2024
Import EtherCAT IO realtime data offline into ctrlX PLC Engineering
Content
This guide shows how you can import EtherCAT IO real-time data into ctrlX PLC Engineering without a connection to a ctrlX CORE.
ctrlX PLC and ctrlX IO Engineering - IO configuration
Requirements
  • ctrlX WORKS needs to be installed
    • ctrlX PLC Engineering
    • ctrlX IO Engineering
Explanation
Case 1: Download from ctrlX CORE
After a download from the ctrlX IO Engineering to a ctrlX CORE the EtherCAT configuration file is located in active configuration (app data) and can be downloaded from there.
ctrlX CORE web UI - EtherCAT configuration file
Case 2: Export from ctrlX IO Engineering
The EtherCAT configuration file can be exported from the ctrlX IO Engineering via right clicking the EtherCat master and choosing "Saving EtherCAT Configuration...".
ctrlX IO Engineering - saving EtherCAT master configuration
If not visible in the engineering it needs to be added by hand.
ctrlX IO Engineering - show save EtherCAT menu
Import real-time data in ctrlX PLC Engineering
When EtherCAT master configuration file is available it can easily be implemented into the ctrlX PLC Engineering via the real-time data node in the "Devices" tree.
ctrlX PLC Engineering - import EtherCAT realtime data from file
Related information
4
IO
