This How-to will give you a step-by-step guide on how to integrate the Wheel Drive Unit (DR1N) from the Robotics Kit ROKIT in the FSoE EtherCat Network of a ctrlX CORE with ctrlX SAFETY
Versions Used and Required Software
ctrlX OS 3.6
Elmo Application Studio EAS 2.9
XML Device Description for ELMO Platinum
ctrlX SAFETY Engineering 1.8.3.10207
ctrlX Apps from ctrlX OS Store
HW Setup & Prerequisites
ctrlX CORE Device (X3, X5, X7) + Power Supply
ctrlX SAFETY Safex Device (C.12, C.15) + Power Supply + Emergency Stop
Wheel Drive Unit (DR1N) + Power Supply + HW STO
Wheel Drive Unit parametrized for HW STO and in Remote Mode (EASII)
PC with the above-mentioned Software installed
Successfull finished the first How To on the Wheel Drive Unit
Important Hint Regarding Safety Systems
In safety systems, all configurations must match each other exactly. The system will only work when the changes are made consistently in the Elmo Settings, the ctrlX SAFETY Engineering and the ctrlX I/O Engineering.
Step-by-Step guide
1. Add the SAFEX to the EtherCat Master in ctrlX I/O Engineering
1.1 Open ctrlX I/O Engineering, right-click on "ethercatmaster" and "Scan for Devices..." and add the SAFEX to the Project.
1.2 The SAFEX is successful added to the project and we are ready to setup the FSoE connections. As the ROKIT Motor is the first Safety Device in the EtherCat Bus, we must change the "FSoE_Connection_1" of the SAFEX. Right-click on "FSoE_Connection_1" and hit "Plug Device..."
The correct size of the FSoE connection to the Wheel Drive Unit for FSoE with STO is the 4 Bytes In/4 Bytes Out connection. The size will remain the same when adding more safety functions like SS1, SLS, etc. If you add the transmission of the safe velocity, the size changes to 6 Bytes In/6 Bytes Out. In this How to, only the STO via FSoE is configured.
1.3 Double-click on the Platinum Drive and move to the tab “Expert Process Data”, choose the “Safety Module Outputs”, mark the second line and change the value via the "Edit" button.
Frequent mistake: Avoid the handling with "+Insert" since the data length will not match anymore resulting in compile-faults.
Select the "STO Command 0x6640" and click "OK".
1.4 Choose “Safety Module Inputs,” edit the second entry, and select the "STO Command 0x6640", exactly as you did in 1.3
1.5 Double click on "ethercatmaster" move to the "Slave to slave" tab, and add the communication from source to destination:
From the safety master to the safety device
From the safety device to the safety master
1.6 Download the project to the control.
🚀 You are done with the Settings in ctrlX I/O Engineering.
2. Change the parameters of the ELMO Motion Controller with Elmo Application Studio
2.1 Connect to the Elmo Drive, either via EoE or as a direct connection via USB on the XF06 connection at the Wheel Drive Unit. After connection, move to the Tab "Expert Tuning" and start editing the "Functional Safety" page.
2.2 Edit Functional Safety Settings
By default, the drive is in "Standalone Mode" which means that FSoE is disabled. Disable "Standalone Mode" and assign an unique "Safety FSoE Address" to the device. It must be entered and consistent to the slave properties in ctrlX SAFETY Engineering, described in chapter 3.3.
Enable the STO Function in the "Safety Control & Status Settings" table.
2.3 On the same "Functional Safety" page, click "Advanced...". You can now choose whether the Hardware STO should be ignored or not. If only the FSoE connection is used, it is recommended to ignore the Hardware STO.
2.4 Move to the "Safety I/O Configuration" page.
Enable "Safe Brake Control" on Output7 with PLd. The standard SBC parameters are suitable.
Enable VDD (required to open the brake)
2.5 Move to the "Sign&Report" page.
Click on "Apply SRA": Now the safety settings are flashed to the drive, and the drive is rebooted.
2.6 By saving the safety settings, a new "Safety Params CRC" checksum was generated. This CRC is required for step 3.3 in the ctrlX SAFETY Engineering.
