02/04/2021
Establish connection of ctrlX DRIVE to EtherCAT control system
Connection to EtherCAT Control (TwinCAT)
Note: EtherCAT is a closed bus system, a direct (parallel) TCP/IP communication with a PC is not possible!
Possible engineering connections with EtherCAT:
  1. USB on the ctrlX Panel
  2. EtherCAT EOE Mailbox (system must be in PreOp or higher state)
  3. ADS Interface (control unit) (system must be in PreOp or higher state)
Step 1: Copy the EtherCAT ESI File (XML file) in the correct folder.
Step 2: Create new project
Step 3: Configure hardware
Step 4: Configure axis
Step 5: Restart TwinCAT Configuration
Step 6: Configuration of EOE Mailbox
Step 7: Configuration of process data
Step 8: Restart TwinCAT Configuration
Step 9: Control the right behavior of TwinCAT
Step 10: Scaling adjustment
Step 11: Restart TwinCAT Configuration
Step 12: Control State Machine
Step 13: Jogging of the axis
