Hello everyone,
as you can see in the screenshot, I tested two different OPC UA Nodes (IoT and Standard Node). Both have the same endpoint configuration but the standard OPC UA node sometimes didn´t connect while the IoT Node is connected.
Did somebody have experience with that nodes?
Thanks you!
