Hello,Â
I am wondering if the following data types / strucutres (OPC-UA) are supported by the CtrlX core data layer
: Localized text
If I try to access the parameter within the data layer the following result is displayed:
null
If I try to access the same parameter using an external tool, e.g. UA Expert the result is different:Â
There is a similar issue supporting "Extension objects"
(see: Gelöst: Betreff: Node RED OPC-UA Subscription to "Extensio... - Bosch Shared (boschrexroth.com))
Thanks for your support,Â
regards Markus
