I would like to write the node:
writing the object as shown directly on the datalayer works fine.Â
I would now like to do the same with a put command from a REST API. However sending the same Object gives an error as shown:
I am guessing I need to change the Object I send in some way. However, I don't know how do I have to adjust this object?
The Type of the Object is as follows:
  "$schema": "https://json-schema.org/draft/2019-09/schema",
  "definitions": {
      "sfk_fbtypes_SfkCmdMoveData": {
         "type": "object",
         "properties": {
            "x": {
              "type": "number"
            "y": {
              "type": "number"
            "z": {
              "type": "number"
            "vel": {
              "type": "number"
            "acc": {
              "type": "number"
         "additionalProperties": false
"$ref": "#/definitions/sfk_fbtypes_SfkCmdMoveData"
Thank you,
