I still get the message “failed to fetch” after I added “deb [arch=i386,amd64] http://de.archive.ubuntu.com/ubuntu/ bionic main restricted” to the sources list “/etc/apt/sources.list” like it is suggested in the setup documentation for the VM and the WSL.
Problem setting up WSL and VM
Best reply by nickH
The Ubuntu mirror used may be overloaded. If this is the case for a longer time, it is best to change the country code in the sources list to switch to another ubuntu mirror (e.g. from “de ” to “ch”).
Change from:
to new:
deb [arch=i386,amd64] http://ch.archive.ubuntu.com/ubuntu/ bionic main restricted
Additional information can be found here.
