In my c++ application, I have some data (array of uint8) that I need to store in the retain memory (NVRAM). This data is updated every program cycle (every 5..10 ms).
On power-off and restart of the ctrlX, the data should be read from the retain memory.
Currently, I'm not sure how to do this properly. I assume that I have to use the data layer for this. But do I just create a node for it as a data layer client or do I have to use RT access to the data layer? None of this worked yet in my test program.
Is there a code example somewhere?
