Active Solution Access
I´m doing some tests with SDK cersion 2.6.7 and CtrlX Works 2.6.3 AppBuildEnvironment. I would like to use Python and access files generated by Node-red or by the PLC app. I would expect to get access to the path '/var/snap/<myapp>/current/solutions/activeConfiguration/node-RED/<file_to_be_used>' but I can´t access, even creating the plug to solutions in my snapcraft.yaml file and changing the package_manifest file to create the directory of my app. Even if I snap the "appdata" sample from github, I can´t see the app solution directory.
