Problem with Virtual CtrlX Core
Good morning,
I have a problem with the Virtual CtrlX Core.
When I try to start it, the element "Offline" turns to "Booting" but nothing else happens and after some time (fews seconds to one or two minutes), it turns back to "Offline".
We tried to look at the emulationΒ process window by activating it in the seetings but it doesn't launch.
I tried too to reinstall my full software but it still doesn't work.
Configuration :
- CtrlX Works 1.18 on a real computer
- With Network Adapter or Port Forwarding
Thanks for your help.
Best reply by danielsimila
I have had the same issue and as a temporary solution you can get around the problem by running ctrlX WORKS as administrator. Does that work for you as well?Β
This is only a quick-fix to not get stuck but hopefully someone can update the thread with the root cause of the problem.
