Replacing SAFEX C.1X device
What are the steps for sending safety project to new SAFEX device via µSD-card? For example, if broken SAFEX.C15 needs to be replaced with new SAFEX.C15.
My assumption is, that only .toc file and .psw file should be stored on the µSD-card and the process is initated during boot up by pressing SF40 button. Is there something else that should be done?
Are there detailed instructions available?
Best reply by AllAutomation
Hello Joonas,
please check the Programming Manual from the media directory: LINK
Chapter 7.7 explains the use case you ask for.
The directory structure of the µSD-card is provided in the Collaboration Room's sub area for ctrlX SAFETY. If you cannot open the following link, then contact your local Bosch Rexroth representative or go through the HubSpot of the ctrlX AUTOMATION Community.
Best regards
Your ctrlX SAFETY Team
