What ist the path name convention for storing / readig files on the CTRX Controller ?
...any suggestions ?
Seems like quite some libraries are not installed to your system.
The libraries come with the normal ctrlX WORKS installation.
Try to uninstall and reinstall ctrlX WORKS.
You can stay on your version as long as you are higher or same as 1.8.
If you have the latest runtime apps with version 1.12, you should also get ctrlX WORKS 1.12.2 in the collaboration room.
/ctrlx-automation-how-tos-qmglrz33/post/faq-for-ctrlx-works-cVdKgsuIAkMuEm4
