About error in generate code
Hello ,
I am using CXA_LICENSING library . I have code by using function from CXA_LICENSING library . Please see attached picture of code . I have problem by using funciton from library . How can i resolve it ?
Thanks in advance
I cannot import your second XML (please try only exporting the POU or application) but when using the first one I will get compile errors as following. You must be able to see similar ones:
ctrlX PLC Engineering - compile errors
After inserting the library CXAC_Licensing to the library manager these are gone. Did you add this library in your project?
ctrlX PLC Engineering - Library manager - CXAC_Licensing
158.12KB
