06/02/2025
Bosch Rexroth | App | Communication
ctrlX OS - OPC UA Server
The OPC UA Server App offers standardized and secure communication in accordance with the OPC Unified Architecture (OPC UA) standard. As an OPC UA server, the ctrlX CORE provides all connected OPC UA clients with all device data. Typical clients are HMI, manufacturing execution (MES) or data aquisition systems. Together with the OPC UA Client App standardized machine-to-machine (M2M) communication is possible.
The OPC UA Server supports the following features
  • OPC UA data access
  • OPC UA discovery services including browsing of data
  • Encrypted communication
  • Handling of certificates
  • User identification and authorization
  • Access to all Data Layer information including plc, motion, system and user app data
  • Supports multi-dimensional arrays (matrices) as data type
  • Access to PLC methods with parameters from PLC type ENUM
  • Support of Data Layer BulkRead and BulkWrite if several nodes are requested in one service
  • Methods can be added dynamically at runtime
A test client to evaluate and verify OPC UA communication is available here.
Support of OPC UA method services and PubSub mechanism is in preparation.
Licensing and scalability
The ctrlX OPC UA Server is available in three license variants. Select the appropriate license according to the size of your application, the required number of client sessions, the number of monitored items.
License
Recommended application
Client Sessions
Monitored Items
Data Types
Basic
Small applications, such as compact HMI connectivity
Max. 5
Max. 2,000
No complex data types (structs, enums and unions) supported
Standard
Recommended choice for typical OPC UA Server applications
Max. 50
Max. 5,000
No limitation of data types
Advanced
Large applications and gateway use cases
Max. 500
Max. 50,000
The Basic license is designed for small applications with a limited number of OPC UA client sessions and monitored items, such as compact HMI connectivity. Complex data types such as structs, enums and unions are not supported.
The Standard license is the recommended choice for typical OPC UA Server applications. It supports up to 50 client sessions and 5,000 monitored items without limitation of data types.
The Advanced license addresses large applications and gateway use cases with increased scalability. It supports up to 500 client sessions and 50,000 monitored items without limitation of data types.
Latest features in version 4.6
  • Web Interface Memory Management: Provides the ability to view the status and perform the configuration of the memory
  • OPC UA Stack Update: Integration of the latest version of the OPC UA stack
  • Cold Failover Redundancy: Implementation of support for redundancy in cold failover mode
  • New License Options:  Availability of new Basic and Advanced licenses
  • Subscription License: New subscription license (1 year)
  • Enhanced Web Interface & Security
    • Icon in the web interface provides link to certificate store and indicates if certificates have been rejected
    • Support for additional security policies: ECC-nistP256 and ECC-nistP384
  • Performance & Monitoring:
    • Implementation of ctrlX DataLayer bulk requests for the OPC UA Service Browse
Curious?
2
Categories
Communication
Platform
ctrlX OS
Vendor
Bosch Rexroth AG
