Why output Active?
Active:=TRUE;Â Jog doesn't work.No alarm error.
It can only be used normally after resetting the PLC.
PLCopen Lib 1.18.0.2
Motion APP 1.18.2
Ctrlx works 1.18.1
Why output Active?
Motion APP 1.18.2
Ctrlx works 1.18.1
You might want to check the standstill windows in the drive in case the velocity dither (noise) is causing this function block to report that it is still moving.
