I am having an issue with a 3rd party node in Node-Red and there's a resolution for it on the github forum but I do not know how to implement it. I will need to run the following command: export NODE_OPTIONS=--openssl-legacy-provider but am not sure how and where to run it from. I usually run such commands from the terminal if Node-Red is installed locally on PC but can't seem to figure out how to do it here. Any help on this is appreciated.
Thanks,
Bala
