EtherCAT analog input configuration
how can I configure the analog inputs EL3102 and particularly EL3702 (with oversampling) in the ctrlX I/O Engineering tool?
Both EtherCAT slaves are detected by the master, however they do not reach OP-state (in contrast to the other connected I/Os).
The slave diagnostics shows no error, however the master shows the error messages "slave init command working counter error"/ "cyclic command WKC error on LRD".
Thank you.
Best reply by rum1
if I understand correctly, there are no problems with the use of oversampling clamps with the ctrlx core, like the El3702. Can you confirm this?
best regards
44.98KB
