Hi, I have 2 ctrlx drives configured in profinet without any usbc drive panel or ctrlx core, is it possible to use XF21 or XF22 as engineering port to connect directly with my pc and being able to switch to different ctrlx drive?
Engineering connection through comm port
Best reply by Jamie
Yes, if not configured through the Profinet controller, you can manually configure your TCP/IP connection on the drive side through the following parameters:
See this section of the drive documentation for reference: https://docs.automation.boschrexroth.com/doc/3824246928/tcp-ip-communication/latest/en/
