I have this ctrlX Core Plus trying to communicate with CtrlX Drive using CtrlX IO Engineering. However this error appears. It there any file that i miss out? If yes where do i get it?
Device description not installed
It seems you are opening a ctrlX IO Engineering project created with anotherĀ versions of the tool (e.g. created in 1.12 and opened in 1.20). As the device description files can change over time you need to update the device to theĀ version used at your side:
ā
