ctrlX core without Battery and expected CR1025 Life
I am working to propose ctrlX core  for a assembly line. It could includes a lot of controllers and replacement of batteries is not an option since it could interrupt production randomly
1) Can the ctrlX core work only with SNTP connection without battery ?
2) What is the expected CR1025 battery life when ctrlX is powered if we must have a battery ?
The ctrlX CORE can for sure run without an battery, as it is only buffering the date and time.
But Currently there is no possibility to switch of the battery low warning, so your ctrlX CORE with light up in yellow if you would remove it or it will be depleted.
See general information about battery in the online documentation "Battery change". There is mentioned "It is recommended to change the battery of the control ctrlX CORE every three years."
While ctrlX CORE is connected to the supply voltage there should nearly no depletion so battery life would be extended but without any estimation. Please beware that in quite old hardware versions there was a Problem that also while supplied the battery depleted. This was fixed from hardware index AG1 on.
