Hello everyone
I've scoured the forum for a solution to my problem, but couldn't find anything that related to it, directly. I've got a ctrlX core with a pretty standard IP address. I'm connected to port XF10, and I can ping the device via command prompt, but that's as much "access" as I'm getting. CtrlX Works can't discover the device, and adding the IP address by hand does not yield any results (i.e., the software still says the core is offline). Typing the IP address on a browser, or trying this solution does not do anything. The device is also not visible on the network. Has anyone ever encountered such an issue? Any help you can provide me would be much appreciated.
