Csv. file save error in CtrlX Core
I have a CSV file that stores the data from each cycle on the microSD card. The problem is that when the card is removed, the PLC does not detect its absence, and I need an error to be generated in that situation.
I am using the "CXA_FileAsync" library, but it does not return any error. How can I fix this problem? If possible, could you provide an example?
