Connect To Core behind NAT
I have a Core behind a NAT router and cannot seem to connect to it. It is translating one Network address to another, so the core has 192.168.1.15, and that should be translated by a NAT from 10.0.1.15. Are there specific ports that need to be forwarded?
Thanks
Best reply by Taste66
That depends on what you want/need. If you only want to have access to the webinterface you need to forward port 443 in incomming request @10.0.1.15 to 192.168.1.15 When this is doen point you webbrowser to 10.0.1.15 and you will get the webpage of your ctrlX-core
