11/13/2024
How-to | Safety
Send ctrlX SAFETY Diagnosis to ctrlX CORE logbook
The function block SAFEX_Send_Diag_to_CORE_xVxx gets the diagnostic information from the function block SAFEX_Diagnosis_xVxx (see: Get ctrlX SAFETY Diagnosis at ctrlX CORE (over EtherCAT)) and send the error text to the ctrlX-CORE-Diagnostics-Logbook.
However, only errors that are related to the inputs and outputs of the ctrlX SAFETY are analyzed and send to the ctrlX CORE Diagnostics Logbook.
The library CXAC_Diagnostics is necessary. So, check whether it is included in the PLC project or add it if not:
Import the attached function block:
Import the function block
Integrate the function block into your program, see example:
Example for the application of the Functionblock SAFEX_Send_Diag_to_CORE_xVxx
If than, e.g. an Plausibilty error occurs:
Example for an Plausibility Error
The Error is logged in the Logbook and can be confirmed with a reset:
Error entry in the ctrlX CORE Logbook
PS: How-to created by Dias; Current contact: Thoomas
SAFEX_Send_Diag_to_CORE_1V00.xml
57.54KB
Safety
