09/19/2023
Port forwarding with a Sick Safety PLC via EtherCat EoE
Some additional settings must be made to configure and program a Sick Safety PLC via the EoE communication protocol.
The instruction is based on:
  • ctrlX CORE V1.18
  • ctrlX CORE EtherCAT Master App V1.18
  • ctrlX PLC Engineering V1.18
  • ctrlX I/O Engineering V1.18
Enable IP forwarding in the ctrlX CORE on the eoe0 connector
  • Open the ctrlX CORE Web interface.
  • Go to the menu point "Settings" and chose the option "Network Interfaces".
  • Activate the switch "Enable IP forwarding".
Enable IP forwarding in the ctrlX CORE for the XF10 connector
Enable IP forwarding of XF10 interface
Setup the I/O configuration
  • Open the ctrlX I/O Engineering
  • Choose Scan for Devices… from the context menu from the item “ethercatmaster”.
  • Double click on the device "Flexi_Soft_Ethercat_Gateway".
  • Activate the checkbox "Virtual Ethernet port".
EoE Settings of the Sick ethercat gateway
  • Activate the window ethercat master and go there to the menu "EoE".
  • Please check if the configuration of the EoE is ok.
EoE Settings of the ctrlX ethercat master
  • The IP address is the same number as the station address. In this example the IP address is 172.31.254.3 and the station address is 3.
Adjustment of Windows 10
  • Now you have to add a route to the windows system.
  • Please start the Dos Box as administrator with the command "cmd".
  • Enter the command "route add -p 172.31.254.0 MASK 255.255.0.0 192.xxx.xxx.xx.
Window adjustment to add a permanent route
Adjustment of the Sick Communication via Gateway
  • Start the program "SafeLogic Desinger 1.8.0 SP1".
  • Edit "com. interface settings".
Start screen of the Sick software
  • Setup the communication settings
Communication settings of the Sick Gateway
  • Then close this dialog and go to the communication settings.
  • Check the communication.
  • If this was successful, activate the profile.
How to check the communication settings of the Sick Gateway
Now you can work with the Sick PLC without an additional external connection.
IO
