11/11/2024
Selmo | How-to | Nov 11, 2024
Installation guide ctrlX COREvirtual and Factory I/O with Selmo Studio
This how-to article explains step by step how to set up UPC UA communication between FACTORY I/O , ctrlX COREvirtual and Selmo studio.
Requirements
  • Selmo Studio 2023.3 SP1 or higher
  • Selmo Basic library 3.0.3.13
  • ctrlX WORKS 1.18.1 or higher
  • ctrlX CORE 1.18 or higher
  • ctrlX PLC app 1.18 or higher
  • ctrlX OPC UA Server app 1.12.5 or higher
  • FACTORY I/O v2.5.2 or higher
  • Trial or permanent licenses for apps listed above
Setup of ctrlX COREvirtual
Step 1 - Installation
Install ctrlX WORKS 1.18.1 or higher.
Step 2 - Virtual Control settings
Use Virtual Control with the following settings
Step 3 - Login
Start Virtual Control and login by clicking "Virtual Control-1“
Login to Virtual Control
Step 4 - Login interface
user: boschrexroth
password: boschrexroth
Login window
Step 5 - Install an app
Click field "Install an app“.
Step 6 - Install PLC and OPC UA app
Install PLC and OPC UA app from local directory.
Installed apps
Step 7 - Server settings
Go to Server Settings, activate "NONE Mode“ and save changes.
Server Settings
Step 8 - Change to "Service"-Mode
Change PLC from "Operating“ to "Service“.
Set to Service-Mode
Step 9 - Open Server settings
Click button "Install an app“.
Step 10 - Select OPC UA Server
Choose OPC UA Server.
Step 11 - Diable Server
Activate button "Disable“.
Disable OPC UA Server
Step 12 - Enable Server
Click button "Enable“ to save changes.
Enable OPC UA Server
Step 13 - Change to "Operating"-Mode
Change PLC from „Service“ to „Operating“.
Set PLC back to Operating-Mode
Settings ctrlX PLC project
Step 1 - Scan Network
"Scan Network“, than search for active devices and log in with your IP address.
Scan Network
Step 2 - Change Runtime Security Policy
Active "Allow anonymous login“.
Step 3 - Install Rexroth License Service Library
Install ctrlX library
Rexroth License Service library
Step 4 - Install Selmo Basic Library
Install Selmo library
Selmo Basic library
Step 5 - Build Symbol Configuration
In the Tab "Symbol Configuration“ click "Build“.
Settings Factory I/O
Step 1 - Open Console
Tab "VIEW“ and choose "Open Console“.
Open Console
Step 2 - Change User Name
Change user name for OPC UA login to: drivers.opc_client.ua_username="boschrexroth".
Change user name
Step 3 - Change Password
Change password for OPC UA login to: drivers.opc_client.ua_password="boschrexroth".
Change password
Step 4 - Search for Host
Search in the field “Host name” for the server: "opc.tcp://virtualcontrol".
Make sure that the following settings are configured:
Search for OPC UA Server
Selmo Studio OPC UA settings
Selmo Studio Settings
Password: boschrexroth
OPC Server Address: specify the Virtual Control used
 Forum ctrlX World Topics
 [email protected] 1)
 Selmo Helpcenter
Selmo Technology GmbH rethinks machine programming and reduces complexity for the programmer. We offer an alternative for manual programming of processes and can translate the process model directly into a PLC program through our algorithm. The Selmo Solution can be learned and applied quickly and easily and immediately creates a standardisation of PLC programming.
FOR SOFTWARE THAT NEVER LETS YOU DOWN
1) Note on data protection
The email is sent directly to the partner company! This company is responsible for the processing of the data contained. Please read their data protection information before sending this email!
Bosch Rexroth is not responsible for the use of the partner company's support.
