09/08/2025
How-to | HMI | WebVisu
HowTo change language with unit conversion in CODESYS WebVisu
Text translation works as follows:
  • Every static text, which you enter in any screen is added to a table (POU> GlobalTextList)
  • In this table you define the translation for the different languages
  • When no translation is defined for the selected language, the original text is shown
  • Table can be exported/imported for external editing
Unit conversion works as follows:
  • The PLC codes always calculates using the base unit (e.g., meter)
  • The HMI converts the PLC's base unit to the desired unit (e.g. inch)
    • Hmi reads value from PLC:
      Convert from m to inch. Example: m2inch.convert(rValue)
    • Hmi writes value to PLC:
      Convert from inch to m. Example: m2inch.reverse(rValue)
Features of the ctrlX PLC Engineering example project
  • Languages: English (en), German (de) and French (fr)
  • Translation of static and dynamic text (=text provided in string variable)
  • Linked units:
Units of
length
temperature
m
°C
language de,fr
m
°C
language en
inch
°F
  • When switching a language
    • text is translated
    • unit values are converted into the unit values of the language
    • unit strings are converted e.g. (m => inch, °C => °F)
    • decimal places of the value are adapted to the unit needs
Basic implementation steps
  • Define languages and translate texts
  • Define unit conversion rules
  • Connect unit conversion rules to edit fields
The attached PLC v2.6.6 project, contains the below shown visualization with more documentation.
set-language-units.project
750.11KB
HMI
Manufacturing
Assembly Lines
Building Automation
Logistic
Packaging
Printing
Production Machines
Robotics
Semicon & Electronics
Sonstiges
