OverviewRequirementsPreparing ctrlX PLC Engineering softwareIL_ECATSoeReadRead string valueRead unit as string valueRead real valueIL_ECATSoeWriteWrite string parameterWrite list parameterNotesRealted links
Overview
The goal is to read/write SoE parameters using standard function blocks from CXA_EtherCATMaster library. All the examples in the following are suited for single axis drives, for double axis drives some slight modifications should be done. In using EtherCAT all REAL parameters are managed as scaled INT/DINT parameters. These function blocks are working also with list parameters.
Requirements
ctrlX OS device
Indradrive or ctrlX DRIVE correctly connected via EtherCAT
PLC and EtherCAT app
If you don't know how to setup the EtherCAT bus just follow SoE drive setup
The first operation you need to do is to import the right library: the CXA_ETHERCATMASTER. Inside there are the SoE function blocks together with the examples, this guide is based on the use of them. Every of the following function blocks needs:
The address to a string variable containing the EtherCATmaster master name, usually "ethercatmaster"
The drive EtherCAT address: usually 1001, 1002, ...
The DriveNo: drive number if the drive is multi axis (0, 1, ...)
The Parameter Idn obtained using IL_ECATSoeIdnCoding Function
IL_ECATSoeCommand
Here an example of how you can use the IL_ECATSoeCommand FB to clear and set the encoder absolute position is shown. The two parameters are both S parameters then the function IL_ECATSoeCommand takes SOE_S_PARAM as first entry. One executed the function remains active until it goes to "Command Executed" or "Error".
IL_ECATSoeRead
Here an example of how you can use the IL_ECATSoeRead function block to read a P parameter is shown. Differently from the previous, this needs as input also the address and the size of the destination variable.
Read string value
Exemplarily parameter S-0-0095 "Diagnostic message: Text" value is read.
Declaration:
// Example B : read a STRING Parameter (S-0-0095)
fbECATSoeRead2 : IL_ECATSoeRead;
rDiagnosis : IL_ST_SOE_STRING;Implementation:
fbECATSoeRead2.Execute := NOT (fbECATSoeRead2.Done OR fbECATSoeRead2.Error);
fbECATSoeRead2.MasterName := ADR(strMasterName);
fbECATSoeRead2.SlaveAddress := uiEtherCatAdress;
fbECATSoeRead2.Idn := IL_ECATSoeIdnCoding(SOE_S_PARAM,0,95); // = S-0-0095
fbECATSoeRead2.ValueAdr := ADR(rDiagnosis);
fbECATSoeRead2.SizeOfValue := SIZEOF(rDiagnosis);
fbECATSoeRead2();
IF TRUE = fbECATSoeRead2.Done THEN
rDiagnosis.Text[rDiagnosis.ActLength]:=0; // FB finished. We make zero termination of string.
END_IF
IF TRUE = fbECATSoeRead2.Error THEN
; // Error handling
END_IFRead unit as string value
Exemplarily parameter S-0-0380 "Inverter DC bus: Voltage, actual value" unit is read.
Declaration:
//Example S-0-0380 "Inverter DC bus: Voltage"
fbECATSoeRead4 : IL_ECATSoeRead;
sS380: IL_ST_SOE_STRING;Implementation:
//Example S-0-0380: Read Unit
fbECATSoeRead4.Execute := TRUE;
fbECATSoeRead4.MasterName := ADR(strMasterName);
fbECATSoeRead4.SlaveAddress := uiEtherCatAdress;
fbECATSoeRead4.Element := IL_ECAT_SOE_ELEMENT.SOE_ELEMENT_UNIT;
fbECATSoeRead4.Idn := IL_ECATSoeIdnCoding(SOE_S_PARAM,0,380);
fbECATSoeRead4.ValueAdr := ADR(sS380);
fbECATSoeRead4.SizeOfValue := SIZEOF(sS380);
fbECATSoeRead4();
IF TRUE = fbECATSoeRead4.Done THEN
sS380.Text[sS380.ActLength]:=0; // FB finished value is unit of parameter.
END_IF
IF TRUE = fbECATSoeRead4.Error THEN
; // Error handling
END_IFRead real value
Exemplarily parameter S-0-0380 "Inverter DC bus: Voltage, actual value" value is read.
Declaration:
fbECATSoeRead5 : IL_ECATSoeRead;
iS380: INT;
rS380: REAL;Implementation:
//Example S-0-0380: Read value
fbECATSoeRead5.Execute := NOT (fbECATSoeRead5.Done OR fbECATSoeRead5.Error);
fbECATSoeRead5.MasterName := ADR(strMasterName);
fbECATSoeRead5.SlaveAddress := uiEtherCatAdress;
fbECATSoeRead5.Element := IL_ECAT_SOE_ELEMENT.SOE_ELEMENT_OPDATA;
fbECATSoeRead5.Idn := IL_ECATSoeIdnCoding(SOE_S_PARAM,0,380);
fbECATSoeRead5.ValueAdr := ADR(iS380);
fbECATSoeRead5.SizeOfValue := SIZEOF(iS380);
fbECATSoeRead5();
rS380 := to_REAL(iS380) /10; // FB finished value is "Inverter DC bus: Voltage".
END_IF
; // Error handling
END_IFIL_ECATSoeWrite
Same as the previous function block but in the other direction. This example can be used to write the homing quota value.
Exemplarily parameter S-0-0141 "Motor identification: Type" value is written.
Declaration:
PROGRAM Write_StringParameter
VAR
fbECATSoeWrite : IL_ECATSoeWrite ;
WriteText: IL_ST_SOE_STRING;
strText: STRING(255):='AKM24D';
MaxLength: UINT := 0;
ActLength: UINT := 6;
bExecute: BOOL;
strMasterName : STRING := 'ethercatmaster';
END_VARImplementation:
WriteText.Text := strText;
WriteText.MaxLength := MaxLength; //not relevant for writing
WriteText.ActLength := LEN(strText); //number of bytes/letters of string
fbECATSoeWrite.Execute := bExecute;
fbECATSoeWrite.MasterName := ADR(strMasterName);
fbECATSoeWrite.SlaveAddress := 1001;
fbECATSoeWrite.Idn := IL_ECATSOEIdnCoding(SOE_S_PARAM,0,141);
fbECATSoeWrite.ValueAdr := ADR(WriteText);
fbECATSoeWrite.SizeOfValue := WriteText.ActLength + SIZEOF(WriteText.MaxLength) + SIZEOF(WriteText.ActLength);
fbECATSoeWrite();
IF TRUE = fbECATSoeWrite.Done THEN
; // FB finished .
END_IF
IF TRUE = fbECATSoeWrite.Error THEN
fbECATSoeWrite.ErrorID;
fbECATSoeWrite.ErrorIdent.Table;
fbECATSoeWrite.ErrorIdent.Additional1;
fbECATSoeWrite.ErrorIdent.Additional2;
; // Error handling
END_IFWrite list parameter
Exemplarily parameter P-0-0397 "Average value filter for display: Time constant" value is written.
Struct:
TYPE MyTableStruct :
STRUCT
ActLength : UINT;
MaxLength : UINT;
ArrayOfElements : ARRAY[0..3] OF UDINT;
END_STRUCT
END_TYPE
Declaration:
PROGRAM Read_Write_StringParameter
VAR
fbECATSoeWrite: IL_ECATSoeWrite;
WriteList: MyTableStruct := (
ActLength:= 16(*number of bytes*),
MaxLength := 16(*number of bytes*),
ArrayOfElements := [1000,2000,3000,4000](*number multiplied with digits after decimal point*));
bExecute: BOOL;
strMasterName: STRING := 'ethercatmaster';
fbECATSoeRead2: IL_ECATSoeRead;
bExecuteRead: BOOL;
rDiagnosis: IL_ST_SOE_STRING;
END_VAR
Implementation:
fbECATSoeWrite.Idn := IL_ECATSOEIdnCoding(SOE_P_PARAM,0,397);
fbECATSoeWrite.ValueAdr := ADR(WriteList);
fbECATSoeWrite.SizeOfValue := WriteList.ActLength(*number of bytes that should be written*) + SIZEOF(WriteList.MaxLength) + SIZEOF(WriteList.ActLength);
fbECATSoeWrite();
; // FB finished .
END_IF
; // Error handling
END_IFNotes
The EtherCat SoE specification is based on the SERCOS II. The structured parameter including the indexes (instance.element e.g. S-0-602.1.1) were first introduced in SERCOS III. Even IDN size changed from 2 Byte to 4 Byte and so access to this parameter "alias parameter" needs to be used.
Realted links
Further examples in the forum
