09/02/2024
How-to | Siemens TIA-Portal™ | ctrlX DRIVE
ctrlX DRIVE with Siemens TIA-Portal™ CPU SIMATIC S7-1200 or S7-1500
Connection of ctrlX DRIVE to Siemens SIMATIC controllers like SIMATIC S7-1200 or S7-1500.
We offer function blocks to drive controlled positioning or parameter access from a Siemens SIMATIC controller over PROFINET to a ctrlX DRIVE or Power Supply.
The function blocks are provided with an example program, parameter file, device description file and documentation to get it quickly running.
e.g.
  • FB_TIA_PN_DCP_cXD function block to drive controlled positioning functionality
    Function Block FB_PN_DCP_cXD
  • FB_PowerSupply function block to control and monitor a power supply
    Example in TIA of the MB_PowerSupply Function Block
  • parameter access via SIP to read and write ctrlX DRIVE parameters, backup parameters
Please note that Siemens TIA-Portal™ itself is not a Bosch Rexroth AG product and is a registered trademark of Siemens.
Download
DCIA_TIA_PN_ctrlXDrive_Vx.x.x.zip
Forum ctrlX DRIVE
Siemens TIA-Portal™ software is a registered trademark of Siemens AG
See https://www.sw.siemens.com/en-US/trademarks/guidelines/ for further trademarks and registered trademarks that might be mentioned in this document.
