IntroductionStart the assignmentChoose your preferred viewSelect licenses Select appsReview in the summary panel
Once your devices and orders are in the same folder, you can assign apps and licenses to a device.
Go to Devices screen
Select 1 to 25 devicesÂ
Click Licenses options > Assign Apps & Licenses
ℹ️ Info
You can also assign apps and licenses for a single device by opening the Device Details screen and clicking Assign Apps & Licenses.
Switch between different views depending on how you want to select your licenses:
Licenses Only – See all available licenses in your folder
Apps & Licenses – View the available licenses in your folder grouped by app
Orders & Licenses – View the available licenses in your folder grouped by purchased order number
ℹ️ Info
You can customize each view by showing or hiding columns to match your preferences.
Select licensesÂ
Each view shows the licenses available in your folder. Here's how to select licenses:
Use the search bar to find the licenses
Check the box next to the license you want to assign
The license will be selected in every view
To assign a license from a specific order number, switch to Orders & Licenses view
ℹ️ Info
Disabled licenses: If a license is greyed out, it may be due to all devices already have this license or the quantity is insufficient for all selected devices. Try reducing the number of devices or assigning the license later.
Follow Pre-Conditions:Â Some licenses (e.g.: CODESYS) have specific conditions. Ensure all requirements are met before updating your device.
Unclassified licenses: If you have access to pre release license, not yet general available at our store, you can find it under the Unclassified app.Â
Select apps
Here's a step-by-step to select an app version:Â
Go to the view Apps & Licenses
Or enable the App version column in the Licenses view
Choose an app version
ℹ️ Info
Selecting apps is optional and selecting an app version
