04/23/2025
How-to | Device Portal | Device Management | Licensing
ctrlX Device Portal - How to download apps and licenses
You have 3 options to download. Apps & Licenses, Apps only or Licenses only.
Choose the option that best fits your workflow, then follow the corresponding upload steps to install on your ctrlX OS Core device.
Download apps and licenses
To download the apps and licenses from a device:
  • Go to the device details page
  • Click Download
  • Select Apps and Licenses
  • Choose a version to each app
  • Click Download
This option includes both the selected apps and the required licenses in a single ZIP file.
ℹ️ Info
Some apps might not have versions available yet in our system — if that's the case go to the Collaboration Room or Store to download them
Download apps only
If you want to download one app specifically:
  • Go to Apps & Licenses page from the menu
  • Search for the app name you want to download
  • Click on Download
  • Select the app version then Download
If you want to download several apps from a device:
  • Click Download
  • Select Apps
  • Select a version for each app
  • Click Download
This option will download one .zip file with all the apps with the device serial number.
ℹ️ Info
Some apps might not have versions available yet in our system — if that's the case go to the Collaboration Room or Store to download them.
Download licenses only
If you want to download license file from one device:
  • Click Download
  • Select Licenses
  • Click Download
If you want to download license file from multiple devices:
  • Go to Devices overview page
  • Select the devices you want to download
  • Click Licenses options and then Download
This option will download one .zip file called Licenses that contain for each device a bin file with the device serial number.
Download licenses for Drives devices
For DRIVES devices all the Drive Parameter files that you have purchased will be available at ctrlX Device Portal.
You can find and download the file at the Apps & Licenses > ctrlX Drives licenses tab. This page is only visible for users that have purchased this type of license.
Services
