Azure IoT Hub - Certificate
Hello everyone,
is there an instruction for the connection between the devicebridge and the Azure IoT Hub? How it is possible to communicate with the devicebridge via https with the Azure IoT Hub and how do you create the certificate?
Thanks in advance.
Best reply by DvB_Support
Hello E_Stapel,
Document / Manual publish might take a week or two for official release
Meanwhile i can assist you generate Pfx certificate / or generate and send you the Pfx to stream data to Azure IoT provided the artifacts (Cert.Pem, Key.Pem, Password) are shared to my email id [email protected]
Hope this helps.
Thanks
Product Support
