webiq-eg Can you please provide an JS example how to read and the attributes (digits, min, max, label,...) of an existing item. I tried to do it, with the help of the documentation (shmi.core.Item & shmi.core.ItemManager), but I failed.
Read and Write attributes of item
Best reply by webiq-sk
HmiGuide WebIQ has a subscription-based model, so your implementation will not work every time.
Here is a working version:
* Custom UI-Action 'readItemProps'.
* Description:
* [Add description here]
(function() {
const actions = shmi.pkg("visuals.session.userActions"); //get reference to userActions object
* Reads properties of an item.
* @param {string} itemAlias Alias of the item to read the properties of.
* @param {?AbortSignal} signal Abort signal to cancel the operation.
* @returns {Promise<object>}
function readItemProperties(itemAlias, signal = null) {
return new Promise((resolve, reject) => {
const { ItemManager } = shmi.visuals.session,
itemAlreadyExists = (ItemManager.getItem(itemAlias)?.type ?? null) !== null;
let token = null,
done = false,
callbackReady = itemAlreadyExists,
/** @type {() => void} */
onAbort;
* @param {string} text
function onError(text) {
if (done) {
// We are already done.
return;
token?.unlisten();
token = null;
done = true;
signal?.removeEventListener("abort", onAbort);
reject(new Error(text));
* @param {object} result
function onDone(result) {
if (done) {
return;
token?.unlisten();
token = null;
done = true;
resolve(result);
onAbort = onError.bind(null, "aborted");
signal?.addEventListener("abort", onAbort);
token = ItemManager.subscribe([itemAlias], null, (name, properties) => {
if (done) {
return;
if (properties.type === null && callbackReady) {
// Subscription has been terminated by WebIQ Server and we
// haven't gotten our properties yet. Assume the item has
// failed.
onError(`Item ${itemAlias} not found.`);
return;
} else if (!properties.initialized) {
// Properties are not initialized yet.
return;
} else if (properties.type === -1) {
onError(`Unable to read properties of item ${itemAlias}.`);
return;
onDone(properties);
// Allow properties callback to fail when type is null.
callbackReady = true;
// Check if the properties callback has already been called. This
// can happen if the item was already subscribed before. We now
// need to cleanup the token because it wasn't available to the
// callback.
if (done) {
token?.unlisten();
token = null;
* UI-Action 'readItemProps' implementation
* @params {any[]} parameters configured ui-action parameters
* ---- Initial parameters, needs to be updated manually when changed ----
* @param {string} parameters[0] Item
actions["readItemProps"] = async function(parameters) {
//Place your code here
const itemName = parameters[0];
const props = await readItemProperties(itemName);
console.log(props);
}());6 replies
