MIN/MAX as a variable
Hi ๐Ÿ˜„ Imagine I have two variables, min and max. How can I use these variables to define the lower and upper bounds for the value range displayed in an input field assigned to a specific variable? Is that possible?
Best reply by webiq-sk
You do not do this at the widget, but at the item level as usually it is the item that has upper and lower bounds.
Simply enter the names of the min & max items (you have to type them manually here, because you can also use special syntax to use values from structures here):
