Input widgets display incorrect values ​​and use incorrect min/max values.
The attached example project uses
Min/Max in item properties
  • Min=1 and Max=10 defined in item properties
  • Min and Max is set to AUTO
  • Correct values for Min=1/Max=10 are used
When you enter a number out of range in
  • iq-button-rocker the displayed number is set within the limits
  • iq-input-field the displayed number sometimes stays on number out of limits
Min/Max in data attributes
  • Min=1 and Max=10 defined in data attributes of widget
  • Min and Max AUTO is off
  • iq-button.rocker the displayed number is set within the limits
Wrong values for Min=0/Max=11 are used by +/- button
When you enter the number with the keyboard, correct limits are used
min-max.mp4
323.7KB
Tested with WebIQ version 2.18 & 2.19
Best reply by webiq-sk
I have created a bug ticket WEBIQ-5486 for this issue. Please note that you did not specify whether this only occurs with MD or also with IQ widgets so we will check that as well.
