Backend Error Adding Alarm SOLVED
I am using the WebIQ designer connected to the CtrlX Core. Whenever I try to add an alarm I get an error that says "Error adding alarm: Backend reported an error while processing API command "alarm.add": shmi:sqlite3pp:constraint:275:constraint failed"
I've tried different properties in the alarm but it always results in this error. Is there a way to fix this?
Best reply by joelphilippage
It looks like the Trigger Item is a required field. Filling this in fixes the issue. Hopefully they will make this alarm more clear to the actual problem in the future.
