Unix Sockets in .NET/Http web api in core
I want build a backend service in my app,Custom API and unix sockets by .NET or Go
,I can built in in windows and use web service,but I don't know how to built in core's app enviornment and install in CtrlX3,are there have some knowledge or sample demo? I can't find this type sample in SDK,there just have front-end service
Best reply by Sgilk
Hi WEI_You ,
1. The proxy mapping will be necessary if there is to be any communication with the application from outside of the localhost. If you are making REST API calls from a PC client like you describe in #2, you will need proxy mapping in the package manifest.
2. Absolutely. You can create your own API reference and make custom calls to your application server.
3. You can set this up however you'd like. Usually, if the application is running locally, you can use Unix Sockets. Otherwise, you'd use TCP. Here is an example showing both methods.
Regarding your test code, a front end isn't required. You can do whatever you'd like here to fit your requirements.
