node.js on core
I see an SDK for developing in node.js in the sdk but the examples are only on the virutal machine. When I try to install the snap on the core I get the following error. Is node.js supported on pysical core?ย
Best reply by DiluMarku
In snapcraft.yaml, you have to set confinement to strict, otherwise you won't be able to install the snap using the web-front.
